alternater recommendations
brm
Hi Folks !
I have a delco one wire alt. on my 200 and it's not working now. I want to switch to a ford unit but I'm not sure what to get. the delco unit worked fine when it was working but I don't like the bracket set up. I don't need alot of amps as the car is basically stock. any idea's ?
Thanks !
Brian
Ideas? Yup, but you'll need to decide if you want an early Ford external-regulated alternator with or without the FalconParts 1-wire regulator conversion, or if you want a later Ford internally-regulater alternator.
I really like my early Ford alternator with external regulator. I guess it depends on how much wiring you want to do, and/or how "stock appearing" you want it to be.
Lots of info here, do a search of all forums for "generator alternator swap" (minus the quotes) and you'll get 8 hits, among them:
http://fordsix.com/forum/viewtopic.php? ... nator+swap
These threads will direct you to other sources of info, like:
http://tffn.net/phpBB2/viewtopic.php?p=48393#48393
http://www.blert.net/comet/gen2alt/
http://www.madelectrical.com/electrical-tech.shtml
http://www.bcbroncos.com/3ginstall.pdf
http://falconparts.com/1960%2D1970+FORD ... ATOR+.html
