The stroke of the 2.3 HSC is 3.3", the 200 has a 3.126" Stroke. The 2.5 HSC has a stroke of 3.58", the 250 has a 3.91" stroke
The 200 and the 250 use the same piston. The oem Ford small six piston is a slotted piston with ~64mm long slots and weighs ~600 grams with the pin.
The Silvolite 2.5 HSC piston is a slotted piston with ~54mm long slots and weighs ~580 grams with the pin.
The skirts on the stock piston are ~11mm longer than the skirts on the 2.5 HSC piston. The 250 has a 1.5 R/S ratio, the 200's is 1.51. The 2.5 HSC engine is better @ 1.67 with a 5.99" rod, the 2.3 is 1.65
The design base of the HSC engine was the 200 block with 2 pistons lopped off.
I would submit that if you rev either of these pistons, stock or hsc, 2000 rpm above redline, or even above 5500-6000, for any length of time they or their rods/bolts will fail esp in a 250. Don't do that :nono:
If you're building a race car or high performance engine and put in some crazy high lift cam with an aluminum head and 4 barrel carb, get forged pistons, forged rods, arp fasteners and balance the rotating assembly.
I hope my piston tops don't find themselves fleeing their bodies anytime soon on my mild 250. The van will be on the road soon. I'll let you know if/when the pistons come apart
