That fitting would be hooked up to a tube near the exhaust manifold. On some models is used to bring warm air into carb top. If you don’t have the extra stovepipe you can make one or it can also be capped off.
Thanks firewall.
Hi Firewall.You do need a little heat to prevent carb iceing.firewall":37jy8iim said:thank´s a lot for all your answers & suggestions. But I´m a little bit confused about this case...I mentioned that I´ve to use all possibilities to prevent getting hot air in the carb
CZLN6":37jy8iim said:You will have to modify the carb spacer that sits between the carb and the manifold.
firewall":l311nphg said:Am I right if I understand that the two corresponding holes (spacer&Carb Bottom) are for leading through the exhaust gases from the Choke back to the intake ?
Best bet for the long run and secure mounting of the carburetor to avoid vacuum leaks at the base might be to make your own adapter plate or find one correct for the 1101, but sounds like you've got it working good for now![]()
CZLN6":3vfcu2b4 said:Howdy Rookie:
The Holley #1940 Was a service replacement for autolites after Autolite went out of business. Since I don't recall ever seeing an Autolite 1100 or 1101 with and electric choke I would doubt that one exists. If they did, Pony Carbs will likely be as source.
firewall":1jepxzqg said:My hot air stove seems to route exhaust
I'm going to do some experimenting with electric choke bodies...if nothing else, junk yard recycles...if I find a fitting substitute for my 1100 I will let you know (I think it should be same as your 1101). I may end up using the auto to manual conversion kit myself...they do tend to offer the most control in limiting unnecessary choking.
