I've been trying to chase down a problem with my car running waaay hot... almost overheating on the interstate. Current setup is a Duraspark II, Holley 1940 (of questionable condition), Timing set at 6*, 160* T-stat, new water pump, hoses and coolant.
Around town it runs fine, temp remains just a hair below the midpoint on the gauge. I feel confident the gauge is okay as it has been replaced at some point by a PO (I base this on the fact that the gauge face is nice and shiny black and the needle is bright red/orange... all of the other gauges are faded).
On the highway (65-70 mph) the temp climbs up to the top of the gauge, just before the H... then I chicken out and get off the highway. At 45-55 mph, the temp comes back down almost immediately... pointing directly at the "p" of the word "temp."
With the DSII, I have now ruled out too much timing advance as the culprit... this leaves the following suspects:
1) Carb too lean
2) Lower radiator hose sucking closed.
Are there any other culprits I need to look into?
I will say that the previous lower hose had the spring in it and this new one does not... did I just answer my own question here? Can a spring be bought or are they integral to the hose?
Thanks in advance for your advice.
1) Carb too lean
