I have a '66 Mustang 200ci and i can't figure this out - Okay, it started when the bolt holding the timing gear on to the Cam fell off completely. When i tore into it i found this, so i re-set the timing and tightened everything back up - but this locked up the crank shaft. Anyway, the problem is when i tighten the bolt holding the timing gear on the cam it locks up the engine. If i add a lot of washers and bring out the bolt to where it sticks out when it is tight it does not lock up the crank. Apparantly the farther into the cam the bolt goes the tighter the crank gets to where it eventually locks up
anyone that can help i would appreciate it
