I replaced the Holley 1908 (from a previous 170 engine) with an Autolite 1100 (P/N illegible). Car appears to run OK with the carb, other than much worse vapor lock as compared to the 1908).
I finally moved my Oxygen sensor & display (narrow band, heated) over from another car to the Falcon. Confirmed what I suspected - the carb is WAY lean at road speeds greater than 50 to 55 mph (unknown RPM, 3 spd trans, 3.2 rear axle ratio, 185R70-14 tires). The O2 gage goes blank (very lean) at about 55 mph. The plugs are now a very light grey in color. I hear knocking at harder acceleration in 2nd gear.
This is a manual choke/manual trans carb. What are my options? I am guessing that the main jet needs to be increased. I did not see any numbers on the main jet when I rebuilt the carb. What are some typicaly jet IDs? how much of a change in dia should I be contemplating - I expect to inch up on the final jet size. Anything other than the main jet to look into on this carb?
After having seized 2 previous engines (170 & 200, pistons swelled up in the bores) I am probably a bit hyper sensitive. I do know that the engine rattles more now that I have 2K+ miles on it (in my car, was told it had about 50K miles on it when I bought it and the lack of oil consumption tends to confirm that). TIA.
