There are 3 steel balls that were not present on the teardown of my carb. Unfortunately, the carb came off of an engine core and I have no knowledge how the carb preformed after its previous rebuild. And based of the P/N, the carb is not original to the engine core (engine core was '66 and the carb is C3UFF). Please see the attached link for a scan of the exploded view of the carb with the 3 balls highlited. One of the three balls does not appear to apply since it refers to a non-144/170/200/250 engine. WHat about the rest?
Second question - what specs do I use with respect to the float height and other adjustments - since I do not know what this carb originally was used on. All I can find on the spec shts is a statement excluding C3UF-F. Now what? Spec sheets attached. Do I use the specs for '63 or '64 (they are different)? TIA
