ok, well the 1 diaphram carb on my engine is starting to plug up since i wasnt able to clean it properly when i rebuilt it, the other 1101 is in peices but is clean, im going to get it working and see what happens
dash pot wuz 4 automatics, but incorrectly placed on some standards (till ford had a service bullitin to remove it @ first servicing). Looks like 2 tiny pie plates placed face to face (ie lips mated, smaller ends facing out). Is external of the carb, has a lill post/rod w/spring around it.
Not clear on the "2 diaphrams" detail as explained...
The Second Diaphragm IS THE DASHPOT they are not all external , got it now Chad , oh and was is spelled WAS not wuz , and where did you come up with the service bullitin , ( your words not mine ) sheesh
Oh, OK, thanks, wasn't aware of that, still learnin.
where did you come up with the service bullitin , ( your words not mine ) sheesh :chill:
I have a lill ephemera (antique papers) from ford.
BTW: think the nomenclature "pull off", to name this mechanic's title for the apparatus, came from this ford mistake in putting them on every vehicle (auto or not) for awhile?
well whoever messed with the carb before me had kung foo grip because the diaphram mounting plates are bent from being over torqued and every time i hit the gas, a little shoots out where the bend is, no biggie
I ran the automatic version of the 1100 on my standard just fine. In fact, one of the mustangs I trust actually recommended it and he puts them on all 200's he rebuilds.
