Autolite 1101 Question
:hmmm: Probably,your best bet would be to find a core and use it for parts.Altho,there are several places on the internet that should have carb parts.
Good luck.Have fun.be safe.
Leo
Those were available from NAPA auto parts in their carb parts. It's been a long time since I bought one, but you might give them a try. Good luck :thumbup: :nod:
Howdy Back:
Do you have that plastic link on your original 1100? It should be the same as on the 1101.
"...to make something up. Any ideas?..."
I like a "wire" the same size (diameter).
Cut something the same diameter, but well over the length of the needed finished product.
Work the middle into the same pattern (take measurements frm the carb linkage) w/a needle nose or 2 &/or a vice.
Cut the long ends off as final operation in the reproduction sequence.
Insert under spring tension. (U may want to cut to final length now, after insertion instead). Operate to test ur results.
Good Luck, never tried it... :arg:
