Not yet. I've talked to Frenchtown Flyer about using the 2150 used in the last 2-bbl 5.0's on one of my X-flows. makes it easy to bolt the factory kickdown cable for my AOD trans.
There should be few issues with it, as long as the vaccum coverner or whatever devices it has hanging off it don't hit the spring tower. The earlier 2100 may be a better fit. Shouldn't be any jetting or vaccum fitting issues, and they come out in cars with similar hp to the 2V 250.
Jet call sizes are Holley, and there is a rich power valve to help the carb run nice an lean when its crusing, rich when it has to be. The only matter of note is the bolt spacings of the carb and any vacuum leaks from the 2V intake, and space for an air cleaner which was only 1.3" inches tall on the Aussie XA's. Get that sorted, and the rest is plain sailing.
