While I was cleaning the venturi clusters, I noticed that one of the emulsion tubes of the primary cluster was cracked.  I read up on this a bit and found it to be a fairly common problem.  Some guys leave it alone, others solder the crack.  I decided to try to remake the tube.  The tubes are .2175" inches outside diameter with a flare on the end of .279".  I found that 7/32" brass tube from the hobby shop is only 125 thousandths too large and 9/32" tube is 225 thousandths too large.  After a few failures, I figured out how to accurately solder the large tube over the small tube to kind of simulate a properly expanded flare.  The emulsion holes in the tubes are right at .040" and I had some .040 drill bits handy (1mm) so I laid a piece of transparent tape over the holes of a good tube and transferred them to the fabricated tube.  Finally, I chucked up the tube into my drill press and sanded the "flared" end down to .279".  I then pressed the tube into the venturi cluster making sure to aim the holes in the same direction as the originals were.  By the way, I did try to find an old carb, venturi cluster, or even replacement tubes but came up empty (for less than $25).  Otherwise, I wouldn't have bothered.
