This past weekend I took my Ranchero on a little over 1,200 mile round trip. I left early Friday Morning and came back Sunday afternoon. The car ran excellent untill I was about 140 miles from home. I just started going up a 7% grade when the engine acted like it ran out of gas. I pushed in the clutch and started to pull off the highway when for some reason I downshifted into third gear. The engine started up and I continued up the grade. About a half mile from the summit the engine quit again, I down shited into third again and it started. After that the engine would quit every so often on hills or level ground. I know it wasn't vapor lock because the outside teperature was in the high 40's When I got home I was to tired to do anything about it. Yesterday I changed the fuel filter and drove the car to see if that solved the problem. The car seemed fine and I thought the problem was solved. Today the problem came back. The whole fuel system is new with only 5,600 miles on it. The Gas tank was boiled out and coated. The fuel filter I removed was clean and there was no particals in it. It is a stock mechanical fuel pump with the filter on it.
Anybody have any suggestions?
