Howdy back:
Start checking at the back of the car, where the fuel goes into the tank. This piece of hose, between the gas filler neck and the tank, is frequently old, cracked, rotted and leaking.
Since gas evaporates quickly, do your check slowly. Watching, smelling and feeling for wet spots or areas. Gas will also run along lines looking for the low spot before dripping. Work your way forward giving special attention to connections- especially rubber hose joints.
Check the line connection into the carb carefully. Once all leaks have been found and fixed, check the carb. Make sure the Automatic choke is opening properly and that the needle valve in the float is not sticking open and sealing when closed. Set the choke as lean as possible.
Make sure your air cleaner is open/not blocked, and working efficiently.
Make sure your initial timing is set correctly, with an additional 5 degrees over what stock calls for. Make sure your whole ignition system is working as designed. Make sure your vacuum advance cannister is working properly along with the mechanism inside the distributor. Make sure your coil, plugs and plug wires are in tip-top shape.
Make sure you don't have a plugged or kinked exhaust pipe. Make sure your thermostat is giving you a quick warm up.
Finally, air up your tires, make sure your brakes aren't draggin', eliminate anything you don't need to carry around- lightening the load, slow down and drive as if you had a raw egg between your right foot and the gas pedal. Coast more- idle less-drive smarter and enjoy the savings.
Tuning for economy:
Hotter is better.
Leaner is better.
lighter is better.
