Jamie Miles
About a week ago, I tried to start my car and the battery was dead. I charged it up, and the car started right up no problem. It was dark out, and I noticed that everytime I came to a stop the headlights and dash lights in the car got very dim. When I took off again, the headlights brightened back up, so I knew the alternator was at least doing something.
When I shut the car off the next time, I tried to restart it and the battery was dead again. The next day I jumped the car off again and got out the volt meter. The voltage at the alternator was fluctuating back and forth between 14.6 and 18.9 volts.
I decieded to replace the voltage regulator. The voltage at the alternator is now holding steady at 18.9 volts. That seems WAY too high to me?
I drove the car around several miles (should have been enough to recharge the battery), and whenn I got back home, you guessed it, the battery is dead once again.
I am at a loss as to what is going on here. If I am getting 18.9 volts at the alternator, and the headlights brighten up when you rev the car up, why will it not recharge the battery? The battery itself is only about 4 months old.
The car is a 1973 Maverick that I am bringing back to life. It had sat in someones back yard in South Carolina since 1992 when I got it. I have driven the car quite a bit in the past 6 months, and this problem just started last week.
