bent push rods
i have a 200 l6 in my ford mustang, i recently put in a cam and when i went to time it, there was no compression coming out of the 1 one piston. so i took off the valve cover and realized that my lifters cant spin... un bolted up my rocker rams and my rod are bent, now i realized that with the new cam i went from hydraulic to solid and i believe thats the reason why they are bent.
what should i do to fix this problem, i thought about using a adjustable rocker arms and/or smaller push rods?? please help i wanna get this car up and running this weekend.
yeah i know i have to get new ones, what about the size of them, should i get the 8 5/16 the ones i have now or get the shorter 8 1/15????
You have to set up the adjustable rocker arms, and use a pushrod length checking tool, if you're not sure.
That said - why should the pushrods have bent? Is valve timing right? :shock:
Have you changes your valve springs aslo? If not have you at least checked to see if you are running into coil bind.
Bent pushrods are usally a sign of mechanical interfenrence.
The adjustable rockers should be able to take up any differences in size. Unless you've had a lot of machine work done then I do as Addo suggested.
He had solid lifters with non-adjustable rocker arms. Which is why I couldn't get my previously owned remanufactured motor to start properly; none of the valves were closing.
on my 170 when the valves were sticking (motor sat for a long time) it would bend the crap out of the pushrods (cup would pop off the rocker) I am guessing he is having the same problem.
Solid lifters are taller than hydraulic lifters, so that's going to compound the problem of using non-adjustable rockers. Which is probably why they bent.
no what happened, was we were going to time it and we carnked it over to get # 1 piston to top dead center, and no air was coming out. i later found out that i had hydralic lifters in there and now with the new cam i have solid..
Mike,
I think you got this backwards. Solids need longer pushrods, so the lifter itself is shorter.
I'll have to verify this when I get home. It to early in the morning to remember......
Will
