At the moment I am running dual fuel, with a gas ring type thing that sits on top of the standard stromberg carb.
I know this isnt the best set up so I want to change it to straight gas.
I am after something that will give me better performance but no worse fuel economy. Well maybe a bit worse fuel economy if the performance is way better, I could handle that I suppose.
It would be good if it would bolt straight on to the standard log head.
Also should I use an upper cylinder lubricant?
What ather adjustments should be made to optimise the use of straight gas (eg. advancing ignition timing etc...)
Thanks
Thanks
