Heh 68coupe, The BB200 in your fairmont is a different creature unique to itself, they only made them from 80-83, when they discontinued the 200. Unless you want to modify the bellhousing and flexplate as Mike did in the tech section, you are stuck with the C5 tranny, as that was the only one Ford hooked to the BB200. When you modify the 200, the tranny is a hindrance as the stall speed is too low and you don't realize any power until you get moving and the RPM's up a little. You can have a tranny shop loosen the torque converter a little, but probably only gain 400-500 rpm's. Also there are centrifical weights in the TC to allow it to go into overdrive, and the tranny shop I went to said that they were a constant problem and they should be removed, therefore making the tranny a 3 speed without overdrive. I am pulling the C5 out of the comet in the next couple of weeks and I will check all the specs against a C4, which I plan on installing per Mike's instruction. Supposedly, the torque converter is deeper on the C5, the bell is deeper to accomadate this and the input shaft is longer. The C5 uses a 164 tooth flex, the C4's usually a 157, the pumps are different and the valve bodies also are different, The rest of the parts are all interchangable between C4 and C5. I will check all this out and post the differences
