Howdy titlelistI6:
How about both. The backcut intake valves will not wear any more than valves that are not backcut. The margin, or width of the seat, where the valve and the seat meet, must be maintained at about .100". The backcut occurs above that margin.
Backcutting not only increases flow, it lightens the valve train. We only recommend backcutting the intakes. Heat in the exhaust side adds another dimension of stress.
If you're only doing a valve job, add a back cut to the intake valves as another relatively cheap refinement.
If you're doing a complete engine rebuild, then add a performance cam in addition to backcutting the intakes.
