A friend and I removed my head a while ago and he noticed a crack that runs next to cyl #1 across the head bolt hole above the header on the sealing surface. its about 2" long but its not really that deep, I know that its still bad. My question is, just to get it drivable again for a while would it hurt anything to just put the head back on and run it as is? I'm going to replace the block anyways but I want to make sure that I don't hurt anything else because of this crack. it was overhauled about 20,000 miles ago by the original owner whom I bought it off of, and i'm pretty sure it was cracked when they did it, but it didn't leak or anything. I imagine that the gasket will protect it from antifreeze getting into the cylinder but probably allow some to escape out the crack and run down the block. advise?
