Thanks Richard for all that info on the gearing, tires and tranny. I am going to file this away for later because I think I do need to do some tinkering in that area. It's good to know I can bolt on an AOD, too.
Right now though so the thread doesn't wander I am going to focus back on the engine rebuild which is nearing completion. I have two issues at present:
ISSUE #1: 289 Spring Specs & Coil Bind Issues
I think I may have a problem with my springs and the new cam/rockers, but I just don't think I have the correct specifications to know for sure. I need to order a spring tool so I can take one off and make some more measurements.
The Classic Inlines website doesn't have quite as much info on their springs as I would like and I have not found concrete specs elsewhere on the 289 springs they sell. CI only gives two pieces of info:
- Installed Height: 1.68" (see here)
- Coil Bind Height: 0.53" (see here)
Why they bother giving an installed height I don't know, this will vary for each build and is something you have to measure. Mine measure at ~1.60" presently.
Also it is confusing because when I think of coil bind I think of the height at which the coils are touching each other (spring completely compressed), but CI defines Coil Bind Height as "Difference between installed height and Solid Height". They don't list a "Solid Height" anywhere for the 289 springs.
Anyway, the Spec Card for my Cam lists:
Valve Lift = 0.480"
What I would really like to know about my cam is lobe lift, not valve lift, since valve lift is dependent on the rocker ratio. I don't know if the cam card really means "lobe" lift or if it is assuming a standard 1.5 ratio, or what.
If my "lobe" lift is indeed 0.480" and I have 1.65 ratio rockers, my valve lift is a pretty incredible 0.792". With my current installed height of 1.60" and assuming a 0.060" safety margin, I'm pretty sure I'm way beyond coil bind with my present setup. But whether I have the correct numbers, I don't know.
Clearly I need some more info... Can anyone shed a bit of light on this?
Of course I can also remove one of the springs and measure "solid height" as soon as I get a spring removal tool.
ISSUE #2: Torque Converter Selection
So far all I have been told about torque converters is that I can't trust the published stall specs. If I am going to "bow to superior knowledge" I'd like to hear what that knowledge would be, but I still haven't seen a specific recommendation. I listed two TCs earlier as possible suggestions, a B&M 2400 and a B&M 3000 but didn't hear anything else from FSD on the matter.
Luke
Valve Lift = 0.480"
Luke
If they have it listed with 1.5 ratio as being 0.441" lift they should know.
