Some Engine Experts should check me out, but here's my prediction model!:-
Rods on US engines are often cast, not forged, so an unshock- loaded 5300 rpm is about it before they want to set adrift. That's around 290 hp with a brilliant head. If you use forged rods and ARP Chevy Big block-style bolts, and something to control splashing oil windage in the sump, you can go up to 5900 rpm, maybee more. In a normaly aspirated car, this is 325-345 hp(net) where there is a great cyinder head flow, and three IDA 44 Weber down drafts hanging off a cut up log or SP/ME/2v head.
As a turbo, you can go to 450 hp on lots of boost 16 lbs+, 360 hp on 9 pounds with a good head and even a stock 155 hp gross (130 hp net, pre 1970 250 1V) could go to 220 hp easily on about 9 lb's. Turbos and superchargers with low compression and good detonation control show less critical loads on an engines bottom end than a noramally apsirated engine. A 250 turbo doing 290hp will be doing less revs than a non- turbo 250 doing 290 hp, no doubt about it, even if the 290 hp turbo has a log head, and the 290 carby non-turbo a 2V head.
Bad cylinder head flow is made-up for when you apply more pressure. More pressure, more flow, less load on your bottom end!
(I don't believe I said that!)
