Bought the Autolite 2100, where's the adaptor?
I bought the Autolite 2100 to upgrade my 200ci Mustang with, thinking that stovebolt or clifford made an adaptor for it. Now that I'm looking for it, I can't find the adaptor for the autolite, only holleys and demons. Maybe I got confused and thought that there were adaptors for both.
If you guys know of a place where I can get the autolite adaptor, let me know. Its the 1.08 size if that makes a difference.
If I can't use it, let me know if you want it. Its in good shape and would only need a rebuild kit and some cleaning.
Howdy Back:
The Autolite is the same base as a Holley 2300- NOT a Holley/Weber.
Clifford has the funnel adapter for this carb to a one barrel hole.
The Autolite 1.08 is rated at 287 cfm. They typically run a little lean in the idle circuit, but all else is pretty good as is.
Good luck.
