Break-in oil
What is the best tupe of oil to use during engine break-in? I just bought a rebuilt 200 with about 1,000 miles on it, but know that break-in takes a little longer than that. The oil look's dirty anyhow, and i need to repalce the pan gasket. Aren't you suppossed to use non-detergent oil or something like that? And do those magnets that attatch to the oil filter work, or are they a waste of money?
S-man
My opinion, FWIW, is to use the same oil you intend to use during the engine's lifetime and change it, and the filter at 500, 1500, and 3,000 miles. Thereafter, I change it at 3,000 regardless. Most machining operations today are far superior to those of "yesteryear" and require much less "break-in" time as it were. :wink:
If anything, the magnet wouldn't hurt anything. You can get magnets for the oil pan, as well as the oil filter.
You might also consider running a screen over your oil filter, to catch any larger chunks before they jam it up. This also gives you a 'tool' of sorts to look for problems while you're changing your oil.
As for type of oil: just whatever you're going to run anyways will do the trick.
Jim
Suppossedly, it has 1,000 miles on it but the oil look's dirty so I'm going to drain it now and then again in 2,000 miles. I know it's not totally broken in my the hone marks on the cylinders I saw when I pulled the plugs. Who know's how it was treated (broken in) during the first 1k!
can you just stick any old magnet to the bottom of the oil pan?
Yeah, you could I guess. But you can't really clean off the metal over time unless it's the drainplug, and it might eventually break loose and flow through the engine. A magnet on the filter keeps the shavings, if you will, in the filter and then it get's changed for a fresh one every 3k
