67-Conv-200
Active member
My starter failed on me today and it looks like it broke at least two teeth on my flywheel. Here is a picture of the one that came out with the old starter:
The car now starts, but there is a least one other tooth broken bouncing around and I hope to go in through the inspection plate and remove the broken tooth. I will also look for which teeth are broken. Now my questions are:
1. Other that the occasional starting problems, what can broken flywheel teeth cause?
2. How difficult is it to replace the flywheel ring gear? My car is an auto with a C4 that was installed in 2010 by a shop (previous owner). I have done some research and it sounds like a big job.
Thanks in Advance.
Thanks in Advance.
