66BroncoDD
Well, I'm on the precipice of starting the engine build. I figure that while I have everything apart I might as well make sure the engine is right.
What i have is a 1966 Bronco with the 170. My plan is to keep the factory 3 speed, Dana 20 T case, and 9" rear with 4.11 gears and a limited slip diff (all of which will be rebuilt).
The engine build is going to start with an early 70s 200cid from a mustang. From there this is what I am looking at adding. I would be interested to know 1) if this system will work for what I want (reliable and stout daily driver that isn't too bad on my wallet at the gas pump), 2) what kind of horsepower and torque you would guess it would produce, and 3) what rebuild kits you have used that you would recommend:
Head – find a head from a ‘77-‘80 200/250 (then mill head .060”, flatten exhaust flange surface, smooth and polish the combustion chamber)
Aluminum Water pump (and add an electric fan. I'm guessing the milling would put compression in the neighborhood of 9:1?)
Valve Train – I'm considering adjustable rockers, but I'm not sure if it's worth the cost
Intake valves – 3 angle valve job & valve back cut
Valve spring retainers – from 4.0 v6 (P/N E6TZ 6A536A)
Pistons - I'm considering flat top pistons.
Head bolt washers – Mr. Gasket (#87 7/16)
Ignition – I like the DUI, but it is pricey. Is it worth the cost over a duraspark II?
Carburetor – Autolite 2100 (1.02 245 CFM)
Exhaust – port divided and header + high flow muffler
Cam - #H-214/290 -2s-12 (Crane Cams)
Any advice you have would be appreciated.
