OK, I've built my "go fast, who cares about gas mileage" engine, that sadly lost it's life to an overheat (moment of silence, please
), but now I want to build a mpg friendly car.
The car now has a internally stock engine in it now with my performance exhaust (Cliffy single out header, hi flow cat, and a generic turbo muffler with 2 1/4 pipe) on it and my full MSD Duraspark igntion setup (coil, 6A, Taylor wires, adjustable timing Duraspark module, beefier ignition wiring harness, stock Autolite Platinums) and it's getting about 20-24 mpg.
What other modifications can I do to get better gas mileage?
!. What would be a good fuel saver cam? I still have my Cliffy 264 cam from the old engine, but don't think it's a good choice for my plans.
2. Should I stick with the little air sucker 1946 Holley? Or should I swap my Holley 2300 equipped head on?
3. I have 3.73s in the 7.5 now and know that dropping to a lower gear would raise the mileage. I don't want to drop below 3.00, but I'm not sure which gears would be best with my stock C4.
Keep in mind that I'm not going for performance this time, this car is a daily driver and I never did drive it like it was anything else. Even with all the go fast parts it never got driven with a lead foot all the time.
Ok, Ok, I lead footed it home sometimes but that was a rare occurrence!
