I have been thinking of making a motor plate to run a SBF trans on a small bell 200. could I just do this....
get a hunk of plate (1/8" steel enough?)
drill a hole for my crank centerline and ream it out to a set size like 1/2"
insert a dowel in the pilot bearing hole to center the plate on the back of a motor and drill the two side holes and the dowelpin holes.
then transfer to the 200 trans to get the two upper holes located correctly.
follow the same procedure for the SBF trans and block to get the plate drilled with all patterns.
all holes would be transferred using transfer punches.
now I know I will need a new flywheel/starter combo for it but was looking at going to a low mount setup as per the SBF. mostly I am wanting to go to a automatic once I start building more power from the turbo motor but would like to keep overdrive for these midwestern roads.
I guess a second side question that might need its own topic is can a C4 bell be modded for an AOD? or is the AOD a integral bell?
