c-4 leaking (with picture)
KustomSkylark
Hi everybody, I got in my car today and discovered it spewing trans fluid on the ground when I put it in reverse. Attached is a picture of where it's leaking from. Is this easily sovled with a new seal or am I looking at bigger problems here?
Thanks in advance for all your help!
Are you saying it's leaking around the servor cover, if so yes there is a gasket under there and it needs to be torqued when re-installed.
It was the seal that goes around the cover. Tricky seal to find a replacment for but easy to fix. Thanks for the help.
Just don't use reverse! :D
A trans shop should have tons of them for about $1 ea.
KustomSkylark":3fjps9eh said:
I went to five trans shops before I found the seal, and they only had one in stock.
Funny.
I'm not a trans shop and I have about a dozen of 'em.
Either way, I have to compliment the original poster on a really clear illustration of the problem area.
Far better than "There's stuff coming out the bottom of my car and it drives funny. Dad says he'll have a look on the weekend but I was wondering if you knew what it is."
addo":2rqrt1aq said:
I have to compliment the original poster...Far better than "There's stuff coming out the bottom of my car and it drives funny. Dad says he'll have a look on the weekend but I was wondering if you knew what it is."
LOL!
Yes, a very good thread-beginning post indeed.
Or - That moment of clarity when you realise you are turning into your parents! :shock: :lol:
