mysavioreigns
I can't keep my car sitting in park. If you take off the shifter bezel and look down in there, you will see that when you squeeze the T-handle buttons, it lifts this little "arm" which allows you to move the shifter into R, N, D, etc.
Problem is, the car is in park: I try to start it, and it won't even try to clank (this is because the car thinks it is in Reverse). I push the handle forward, and it "nudges" a hair. It then starts fine. It is like it can't distinguish between Park and Reverse, unless it is pushed all the way forward.
The biggest problem is, I'm afraid if I leave it in park, and it gets windy or something, it will slide into that "reverse" area, and start rolling.
Parking brake doesn't work either, that would help a little, but that's another story.
