I *think* Bill has it right, though it is always vague to set up a cam because:
a] they are not always ground "straight up" - That is, if the cam is a 112 LSA (Lobe Separation Angle), "Straight Up" would be LCA (Lobe Center Angle) of 112i (Intake) and 112e (Exhaust).
b] The chain/gear sprocket is sometimes marked in CRANK degrees, but sometimes marked in CAM degrees. Best way to find out is to check with a degree wheel.
In your case, my *guess* is that:
a] Your cam is a 112 LSA, but it is ground with about 5 degrees advance ground in. So dot-to-dot, you'd have 107i LCA and 117e LCA.
b] You used the +4 setting on the gear which is probably crank degrees, so now you have 103i LCA and 121e LCA.
But it is also possible that:
a] Your cam is a 112 LSA, but ground straight up, with 0 degrees advance built in. So dot-to-dot you'd have 112i LCA and 112e LCA.
b] Your gear is marked in CAM degrees. So at +4, you will advance it 4 CAM degrees which is 8 CRANK degrees, giving 104i LCA and 120e LCA, close to what you measured.
I would use the "0" setting on the gear, and check the Intake LCA and the Exhaust LCA to see where you are.
The best way to get the LCA's is *not* to use the point of max lift, since that is very insensitive so you can be off by several degrees easily. :nono:
So the best way is to look at the .050 opening and .050 closing on the wheel, and go halfway in between.
Then post back and see what's what before you button things up.
While you have the degree wheel and dial indicator on there, I always measure at least one intake and one exhaust lobe even on a new cam and degree it to get the degrees at :
Intake:
.006 lobe open
.020 open
.050 open
.100 open
max open (which you said was 103 ATC right now)
.100 closing
.050 closing
.020 closign
.006 closing
Exhaust:
.006 lobe open
.020 open
.050 open
.100 open
max open
.100 closing
.050 closing
.020 closign
.006 closing
One reason is that "Back in the day", Neither Ford nor anybody else reported the standard ".050 lobe lift duration". But, Ford did list .100 lobe lift duration, so this is handy for comparison. It will also give you the "ramp rate", which is handy for assessing valve spring needs.
Good luck, it is a lot of measuring. But I have never regretted degreeing a cam.
