Hi, Just wondering what is normal. I rebuilt a 200, used the Comp Cams 252H kit. I did use assembly lube, and oil additive. Oil pressure is good. At 1000 miles had lifter noise and had to adjust. Now at 1200 miles I have slight lifter noise again. Is that normal or do you think I have a cam problem? Also the thing just doesn't idle as smooth as I would expect. I have the Classic Inlines universal carb and the Duraspark ignition kit. Is anybody else out there using this cam? Thanks
