All Small Six Camshaft break in and transmission fluid levels
clochard68
Subscriber
Supporter 2021
Supporter 2022
Supporter 2023
My C4 automatic got a shift kit and new oil pan.
I reinstalled everything and filled the transmission up to the full mark. It sat for almost 2 years now. With my new camshaft there are a few questions that are critical for a (transmission-) safe break in:
When I break in my new cam, do I just check the trans fluid level while breaking in and add fluid if it gets to low? Or do I overfill it at first?
Is it even possible to check the level when the engine revs around 200-2500rpm?
Do I keep the transmission in park or in neutral?
So many questions I am sorry but I want to keep the C4 healthy ;)
The camshaft breaking in doesn't really have anything to do with the transmission, other than making sure the transmission is in Park while you're breaking in the cam (20-30 minutes at a steady 2500-3000 rpm is the standard). I would suggest putting a zinc additive in the engine oil before you start the break-in process.
As far as the transmission, the fluid should be checked after the transmission is warm (the engine has run for a while, as in after a cam break-in). If it shows low, then add until it's in the proper range on the dipstick. You should avoid overfilling.
Thanks John!
Then I will leave the transmission in Park and check levels as you suggested.
The transmission fluid level has to be checked with the engine running and at operating temperature.
