Can someone Identify this Autolite?
choppermike
1100 or 1101? No SCV No Tag
without a tag saying it is a posrt SCV 1100 (68 and newer) or an updated 1101 is the best I can do. Maybe there is something on it that you could measure like the venturi to help identify?
-ron
Howdy Back Mike:
It is either a 1968 or '69 C/E (Calif Emissions) 200 carb, if it has a 1 7/16" throttle bore, or a 1969 1101 which will have a 1 11/16" TB. Other then the TBs they look very similar.
If it is a C/E carb it will be down on cfm compared to SCV 200 carbs- 150 to 185 CFM. It does have a ported vacuum source for a real vacuum advance distributor (Not- L-O-M).
It wos originally from an engine that had an automatic trans.
If you are looking for a kit for it try 96-333 at your local parts house. They will probably have to order it. I just ordered two today and will pickup in the am. It was a Carter Carb YF. Atleast that was what mine is and it looks the same. Good luck.
