I have an 1101 from Pony that is 1.75" on the throat. I also own a Weber progressive 2bbl. In the last month, I have bad hesitation from launch and in any gear. It starts, idles and revs incredible..as always. But under load..she bogs bad enough to die. I have checked plugs, dizzy, vacuum lines, etc. I finally found a bad gasket between the carb and adaptor. I replaced the carb gasket, but still have the problem. Is this a power valve problem?
Also, I am going to purchase adaptors from Mike but I have a question that fits both carbs. On the mating side of the 1101 carb (to adaptor) there is a small canal the ports to the throat. I assume is for the idle circuit. On the 2bbl there are two holes in key positions also ported to the throat, I assume is for the same.
When I look at the adaptors from Mike, I do not see the mirror image canal. When I looked at my old 1bbl spacer (with the coolant tube) it is there.
What exactly is this canal for?
Lastly, If I get the vaporizer adaptor that mates a 1.5 to 1.75 on the intake....will it still work well with my 1.75 1101?
Thanks...Jim
Thanks...Jim
