Green streak- Have you done the distributor yet. Almost always when these carbs don't work right the distributor, or its vacuum system are at fault. Be sure to check the hot air choke systems too.
David; I don't really know much about distributors or how to properly adjust the Vacuum advance or even set the dwell for the points. Any resources or suggestions? (I have a shop manual on order through E bay just waiting on its arrival)
Via Con Dios, GregC
