philford
back when you checked comporession they were very low.
then you entioned it was struggling to crank.
check the ground cable to your battery is actually grounded. to the body and as well to the starter. Id remove the cable completely clean it and replace it.
I just had that issue and it caused bad charging and bad cranking.
youc an check the hot to starter as well,
when doing the comporession test your crranking speed really should be normal it will skew your readings.
if your compression is still that low borrow a different guage make sure its not just the test guage.
you can buy one , but being cheap I I just knocked the porcelain ffrom a spark plug then took a tubeless tire valve from an old rim . I ground ithe rubber down enough ( bench grinder) that I could shove the tubeless tire valve in the spark plug..
then connect the spark plug to your compressor tank , let your compressor charge its tank then turn it off so its quiet.
you can hear it leaking , if the engine gets either way past TDC ,
if you rock the engine either direction from TDC it will try to turn the engin suddenly driven by the compression in the bore, toward BDC so be careful , it can move suddenly !
if you put it so both valves are closed then compress it right at the top of its stroke, then assuming both valves are closed you can hear air leaking. you may decise one is real bad/ you might open ethe oilpan or hear it coming from the manifoild or out the exhaust pipe.
to get the engine ot that position turn it until #1 expells, put a wad of moist pa[er towel int he plug hole or your finger over it to detect air leaving.
once air is leaving that is the compression stroke. you are turning its normal direction nto backwards.
you can put a plastic drinking straw in there and watch so you can find the peak of the piston , you are now at TDC of cyl 1 with both valves closed.
other piston holes , similar process,,
if one piston has a huge leak you may hear it that may indicate a chunk missinng from a piston or a valve.
if you have a chunk missing from a piston or valve you' ll also have low compression readings for the same cylinder.
the reason you'd wan to do all this is to prevent taking apart an engine that doesn't need to come apart. or to verify the above is the case..
I think you need to figure out why your compression readings were so low, you should be seeing 150 on each or somethign close. if you had 100 on each that may run, if you have really low compression I'd open it. but make sure the low readings are not just the result of the compression check not being done correctly.
to turn the key and hold the compression guage get a helper or you can rig up a button ...lots of test kits came with a ( jump ) button and cable for that. you basically need ot energise the relay in a ford it wont be on the starter motor , maybe near the battery, folloow the battery hot cable. many other cars have the solenoid as part of the starter motor. energise the solenoid and it cranks.
if you do that make sure its not in gear as you are over-riding any prevention and you can run yourslef over or it can possibly run away and cause harm if it does start. that can knock it off a jackstand etc.
