I'm neither saying the 2100 nor the 1.14 are pieces of junk as a whole, just the one that i had. lol
I bought it rebuilt from an online seller. I took it apart when I got it to make sure that it was indeed rebuilt and not just cleaned up on the outside. It looked like the company did a thorough job on it, but since the day I installed it I just couldn't get it to run right. As time went on, it started to get worse. So, I rebuilt it. It didn't fix the problem (whatever it was/is). So, I installed the very same holley that you recommended, tuned it a bit, and my car has literally never run better. I'm thinking that it has to be something wrong internally with the carb. I've tried playing with the float and got minuscule results from that. I have NO vac leaks, no problems with over heating (even with AC), timing is set at 12*, cam advanced 2*
As soon as I can figure out exactly what is wrong with the autolite and fix it, it will probably go back on, or I will save it for something else. I was thinking about using it when I try my hand at going boosted...
