james singleton
Does anybody know what effect you will have running a "NON" SCV (Spark Control Valve) carb with a Load-A-Matic distributor instead of the called for SCV carb???? Will it be just a performance thing; or will the engine not operate effeciently at higher speeds (or lower speeds/@idle??), or what??? The reason I ask is that in rummaging through some of my old parts today, I noticed that a Motocraft 1940 carb that I had problems with many years ago was a factory produced "Non" SCV carb that I had installed with my Load-A-Matic distributor not knowing any better at the time! It had run fine for a while, but then started dying at idle! So what effect does a Non-SCV carb have with a Load-A-Matic???? Thanks, Jim
