For Sale *SOLD* Ford six 144/170/200/250 distributor, wires, cap, rotor
Dunk
Distributor, cap, rotor, wires, points, etc. removed from a Ford small six cylinder 170 in a '64 Falcon. Distributor shaft is later model ('66 up?) larger 5/16" oil pump drive but is load-o-matic style, no mechanical advance, need a SCV spark control valve carb.
Cap, rotor, wires, points are nearly new with only a few hours run time. Distributor bushings are tight and diaphragm is intact. Distributor will not work with early engines with 1/4" oil pump drive.
Distributor housing PN: C4DE-12127-A
$50
Located near Philadelphia, in 08081.
