61 comet
What was the purpose of running hot coolant under the carb through the spacer? Can you just bypass that, or is it nessasary?
The power valve on the side of the carb, on any other carb I've worked on it had a cover. Shouldn't these be covered? My carb doesn't have one. I cleaned a mud dobber nest out of there. And wondered why there was a big hole in the side like that. I found images of carbs when I was trying to figure out what all is missing for the throttle linkage.
