Actually, now that I think about it, I am wong. There were a few rare (200 I think) GN's made in '82 & of those I believe only 20 were turbo'd.
The wife reminded me about that.
I own two '83 T-types & have 3 spare turbo's. I've been wanting to stick one on my 200/6 for the longest time now. I just haven't had the time, too many projects. They do look like they were made for each other don't they?!
I wouldn't worry about the egr. Mine have been blocked off for a long time & I've had no-problems.
Buick used to use vacc. to close off (SEVERELY restrict) the air intake trak & they used a heat riser from the exhaust manifold. My '83 carb. bases have an electrically heated gasket to help also.
Literally ALL this stuff has been removed from one of my T's & I don't miss 'em one bit. All just crutches in my openion.
How did you run your exhaust? Under the oil pan & over the valve cover or did you just loop it around on the pass. side?
How did the turbo's outlet size & the intake log's hole match up? I was thinking of mounting it using a thick spacer mounted to the log & tapped for the turbo or tapping holes right in the log for the housing but this would put it lower than I think I want it?
The 82-82 turbo's have the smallest exhaust housings, .62 the earlier ones were .82.
There is a person selling complete chra's on e-bay for around $100. That's prob. the cheapest way to rebuild.
Good luck with your project. You'll probabley beat me done.
