charlie's 68-6
hi all, i have a 68 mustang with a 200 hedders(thanks mike) 2.25 pipes all the way back with mufler shop turbos.i fabricated an adapter to put a carter/motorcraft 1 barrel from a '77 250,i turned the adapter to have the throttle tip in to the head versus the front of the engine,the car runs great however i can't get the idle down below 1100 rpm at idle,manual transmission in neutral,it runs so rich that its almost not fun to drive. where is the idle jet on this carb and where can i get a leaner size ?the number on the base of the carb is 7287S no other numbers anywhere.
thanks in advance
charlie
charlie's 68-6
thanks in advance
charlie
charlie's 68-6
