Carb
Ba Mustang
What is the maximum cfm carb i should buy for an I6? Got birthday money and looking for a 2bbl carb to replace 1bbl.
Either the 350 Holley or the H/W 5200 are good choices. Or a Weber around 32/32 or so. Some have had success with carbs as big as Weber 38s or Holley 500s, but for a lightly modded motor, the 350 or 5200 is your best bet.
Howdy BA M:
More information would be helpful to give you a meaningful suggestion. Are you looking for a 1 barrel bolt-on replacement? Or something that requires modification and/or adaptations? There are reasonable options in either case.
Another consideration is what distributor you have on your engine? Early 200s have a carb-distributor combo that are somewhat dependent on each other. Changing one will compromise the function of the other.
Depending on your circumstances and goals, a distributor upgrade might be worth considering.
Also, let me suggest that you create a logical, sequential plan so that what you do with this birthday money can be complimented by your next purchase and you end up with a complimenting package. With bolt-ons that would include, 1 improved exhaust, 2 improved distributor, 3 improved carburetion.
Don't forget safety issues as you go along too.
How about some more info on your car and your longterm goals for it.
That adapter will be a bolt on in the sense that the carb and adapter will bolt on without mods. However linkage will need to be fabricated or a cable throttle installed. The 350 holley it uses is a very good tunable carb right out of the box. Take your dizzy cap off look at the plates if springs are visible you have a load o this dizzy wont work with a new carb so you will have to do a duraspark conversion read the top sticky this is one of the best cheap upgrades you can do. If plates are visible you have a non load o and that while a duraspark is still better will work with a new carb.
Dan-
BA Mustang":190c2wvk said:
and JackFish so far i have 255.
I went to the junkyard a few times and pulled a couple of 5200s and Autolite 2100s that were in various states of working condition. And bought a couple of carb kits cheap off ebay. Probably spent about $150 altogether, and have a nice little stash to tinker with.
If you take the JY route you could save some cash to put towards other upgrades. Like a few DS2 parts while you're at the JY... :)
I wouldn't do the carb. I'd dial the current cam, send it away for a mild regrind, replace the timing chain and lifters upon refit and see if I had enough left over to skim the head a little. Then fit a GM HEI module and a used Ford TFI coil, triggered by the points.
