62Ranchero200
This discussion has been very helpful for me re: milling off air horn.
On my baseline dyno, I made the most torque and HP without the air cleaner; and the hood was open the entire time. Under those circumstances, milling off the air horn probably won't produce much benefit, or could even hurt air flow as MustangSix points out. But when running the 1/4 mile, even running without an air cleaner, carb-to-hood clearance is definitely limited as xctasy points out, so the air horn delete might offer some improved air flow. On the street with an air cleaner, the improvement of the air horn delete may be even more pronounced than on the 1/4 mile.
I like the idea of trying a stubstack first on the dyno before the air horn delete. Non-destructive mods first.
Note manifold vacuum at WOT - I can certainly do that by teeing into the vacuum modulator line where the choke was formerly teed in.
On a side note, am not independently wealthy (if I was, my daily driver would probably be a Ford GT or perhaps a Cobra replica), so may reach a point where I have made so many modifications to the Holley 4412 that am reluctant to abandon it. Will probably try to squeeze as much power as I can out of the 4412 before I consider switching carbs, probably to a 4 BBL, which may require cutting the Falcon-like shock tower and/or modifying the throttle cable setup.
Bob
Bob
