BCOWANWHEELS
Whats the outside diameter of the heat tube on a 250 engine with a carter rbs carb please ? also isn't the tube to carb connector a standard fitting with ferrel inside ?
THANKS
BOB
THANKS
BOB
chad":3l3f7ftj said:TRADE YA:
Who has the oil pump hex drive shaft to chuck in your driver to pre lube (pump up) on 1st start up?
chad":ess35mee said:RC -
i saw that earlier - does it fit in & stay thru the operation?
I'm all ways 4 cheeper!
RichCreations":svl8qwq1 said:chad":svl8qwq1 said:TRADE YA:
I just use a 5/16 socket nut driver and a long extension chucked in the drill
chad":1k07ndke said:"…this type of method ,you can gouge up…"
I'll soon B upon this stage of the ssembly process. Got nother suggestion?
I'm gunna pack in a lill assembly grease, then wanna spin the pump to draw in/distrubute the special crancase break-in oil, & run it 20 min @ 2,ooo rpm.
Sorry, gotcha.BCOWANWHEELS":3tv5v9jt said:guys, please start your own thread…............
