So, my engine runs great and makes decent power, but it raises a clamourous racket above about 3500 rpm at full throttle. At first I though it was the normal behaviour of an old pushrod engine, but it does sound especially busy. Then it ocurred to me that it might be very dramatic detonation that I just didn't recognize because I've never heard it like that before. Now, after retarding initial all the way to 4 degrees with no change, I am back at about 12* initial and it sounds the same, and no pinging anywhere. AFR is about a steady 13.5:1 at WOT all the way to the shift. Any suggestions why my engine could be so darn noisey, or is it just the way they are.
FYI this is a 200, with full roller rockers, stock cam, stock bottom end, cc 51.5 and deck is around .025 with a fel-pro gasket (cr about 8.7:1 ??). DUI ignition with 24* advance at 3k, weber 38/38 direct mount on ported head with the big valves, 302 springs.
