Upon my return home from Hot August Nights last summer, a couple lifters were singing pretty good. The next day, I pulled the valve cover off and saw there were a couple pushrods that were loose. My machist thought I ate the camshaft lobes but I finally got around to pulling the head off last night :roll: and the cam seems fine. There are no score marks on the cam or the bottom of the lifters, therefore I am assuming I have a couple bad lifters. The motor was completely rebuilt the summer of 03 and has approx 7000 miles on it. The cam is a COMP 260H however I used stock TRW lifters when I did the rebuild because they were free. I also converted to the adjustable rocker assy at that time. My machist said the lifters would work just fine.
I don't want to go thru this again, so what is a good brand of lifter to get? Should I get the Comp lifters that are made for the CAM? Other than soaking them in oil, do I need to do any breaking in stuff to the cam when replacing just the lifters?
