OK, well I'm picking up a 79 200CI from a Fairmont to use as the starting point for my engine build. I have a couple questions for all you CR gurus out there.
I understand that the heads on 77 and up are the same on both the 200 and the 250. They have a 62cc combustion chamber. OK I can understand why you would need a larger combustion chamber to compensate for CR on the 250 with it's larger displacement, but why on the later 200's? It seems that the larger chamber will drastically lower the CR. I have the Falcon Performance Handbook, and it really doesn't go much into it. Although it does say that 73 and up pistons had a 13cc dish in the pistons, which seems like it would make the CR problem worse.
Are there any fundamental differences between the early and late 200's? I know that in 79 Ford started switching to the low mount starter, but the one I'm getting has the high mount.
Did the late 70's 200's have a much lower CR? If so, is there any problems milling the head to bring it back up? Should I use a piston with a smaller dish or a flat-top?
I just don't want to go off half cocked and break something due to ignorance.
Kris
Kris
