SoCar72
I think I'm missing something...
According to Motors Manual specs for the '63 170, the CR should be 8.7:1. Given that average atmospheric pressure is 14.7psi then a compression test should yield 142.59psi ((14.7 x 8.7) + 14.7).
Testing my still original engine, my average was about 150psi (overall range of 7psi). This suggests that the CR is more like 9.5:1.
Furthermore, Motors Manual states that a fresh build should test at 170psi (+/- 20 psi
) for the 8.7:1 which computes like a 10.5:1 - 12:1 CR.
Are the "build" CR's spec'd as dynamic ratios whereas the static is considerably higher? Or is this some anomaly generated by the inline configuration? I did notice, again according the Motors Manual, that the 221 - 260 V8's of the same or comparable CR were spec'd to have a significantly lower compression test pressures, figures closer to what the math predicts.
What am I missing?
What am I missing?
