Ok I have been doing some number crunching and I am confused. According to the manual, and my own calculations the stock compression ratio for a 1965 ford 200 cid engine is 9.2 to 1. Now I have also read in the ford I/6 performance handbook on page 16, “The generality is to run a compression ratio that matches the octane rating commonly available to you. For example: if you choose to buy 87 octane pump gasoline, then plan for 8.7 to 1 compression ratio.†So my question is that if the car is running a 9.2 compression ratio and it was made to run on regular gas then how does this work. I basically want to know if I run regular 87-octane gas can I have the “stock†compression ratio of 9.2 to 1??? Thank you for all your help!!
thanks
kevin
thanks
kevin
